Activity Forums Adobe After Effects Expressions Change keyframe value of a Time Remapped Layer
  • Change keyframe value of a Time Remapped Layer
    Posted by Quest Rogers on August 9, 2016 at 4:19 pm
    Hello. Hopefully someone can help with this. What I’m trying to do is simple in theory about I couldn’t find an answer in other threads here so I thought I’d post it.
    I have a comp with a layer that has Time Remap enabled with only two keyframes. The value of the first keyframe is 0 and that isn’t going to change. But I’d like to change the value of the second keyframe with an slider on a control layer. I’m not sure how to write the expression for this. If anyone has any ideas I’d greatly appreciate it.
    Edit: I know I can just move the keyframe up or down in my timeline but I’d like for it to be connected to a slider on a control layer because I’m making a template for editors to use and I don’t want anyone changing the original layers.
    Quest Rogers replied 10 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 9, 2016 at 5:32 pm
    Something like this, probably:
    if (numKeys == 2){
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = key(1).value;
    v2 = thisComp.layer("control").effect("Slider Control")("Slider");
    linear(time,t1,t2,v1,v2);
    }else
    value
    Dan
  • Quest Rogers
    August 9, 2016 at 7:47 pm
    Thanks Dan. This is exactly what I was looking for. I wrote of what you had except I was getting syntax errors for the lines with values. Thanks again!
