Activity Forums Adobe Premiere Pro Change keyframe range in timeline
  • Change keyframe range in timeline
    Posted by Alfredo Canziani on December 28, 2016 at 12:28 am
    I’m trying to ease out a scaling effect. So, I thought that using the keyframe in the timeline could have been a reasonable idea for editing the Bezier handles.
    Here you can see the opacity chart, of the grey clip, is set to 100% as it is the scale effect of the central clip, on the far right hand side. Unfortunately it is squashed to the bottom of the window, and makes it unusable.
    I would like to make it look like this, but without having the initial scale set to 10,000.
    Is there a way to change the range (y-axis) of the keyframe chart in the timeline area?
    Thank you.
    Alfredo Canziani replied 9 years, 8 months ago 1 Member · 1 Reply
  • Alfredo Canziani
    December 29, 2016 at 4:49 pm
    OK, I’ve figured it out. One has to use the Effect Control panel. The Timeline Keyframe view is pointless and misleading.
    Here there is a view of my panel, where I can control both the x and y range.
