Activity › Forums › Adobe After Effects › Change Info Settings?
Posted by Jerry Smith on June 14, 2017 at 11:32 amHow can I have the info panel give me the color hex? I need a convenient color reader.
Walter Soyka replied 9 years, 2 months ago 2 Members · 3 Replies -
Walter Soyka
June 14, 2017 at 2:36 pmClick the hamburger menu button at the upper right corner of the Info panel, then choose “Hex” as the color display format.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Walter Soyka
June 19, 2017 at 3:00 pm[Jerry Smith] “I’m still using 2014.3 mostly. I guess I’m out of luck.”
This feature goes way back! Here are a couple of screengrabs from Ae CC 2014 to illustrate the process:
Click the “hamburger” menu at the corner of the Info panel:
Select “web”:
Now your color readouts in the Info panel will be hex:
Walter Soyka
