Activity › Forums › Apple Final Cut Pro Legacy › Change frame size in Final Cut Express
  • Change frame size in Final Cut Express
    Posted by Artisan949 on January 9, 2006 at 8:27 pm
    I have footage that is 320 x 240 that I want to edit in FCE but the only option the program gives is to edit in a 720 x 480 canvas. When I render the video, a thick black border appears around the video. I’ve gone to Easy Setup and there is no 320 x 240 setup and the custom setup is not customizable (at least I haven’t figured out how to customize it). I’m so frustrated. If anyone could help, I’d be so greatful.
    Enzo Tedeschi replied 20 years, 8 months ago 2 Members · 1 Reply
  • Enzo Tedeschi
    January 9, 2006 at 8:56 pm
    FCE will only work with DV. You will need to convert your file first to scale it up – Quicktime Pro perhaps, depending on your file’s codec? Or maybe mpeg Streamclip. Be aware that you will suffer some quality loss.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
