Activity › Forums › Adobe After Effects › Change frame rate witout dublicate frames?
  • Change frame rate witout dublicate frames?
    Posted by Julius Valentinas on January 4, 2016 at 3:19 am
    Helo, in after effects
    1. I create a comp with 30fps,
    2. then I import a file sequence at true 30fps as 24fps using interpret footage -> main -> assume this frame rate
    This makes what I want, except it makes duplicate frames. Any way around it?
    Kalleheikki Kannisto replied 10 years, 8 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    January 4, 2016 at 8:52 am
    Any reason not to make the comp itself 24 fps?
    Dividing (or multiplying) the frame rate with an integer, making it 15 or 10 fps, is a better option visually. You could try using pixel motion frame blend to attempt to create in-between frames, but that is rarely flawless.
