Activity Forums Adobe After Effects change frame rate of keyframes
  • change frame rate of keyframes
    Posted by Mihai Wilson on November 18, 2008 at 6:30 pm
    Hi, Im wondering how to change the spacing of keyframes based on frame rates. I have a 24fps comp that has a lot of keyframes spaced evenly at 24fps (1 key per frame). I want change the comp to 12fps, and then move the keys to 1 per frame at the new fps. Any way to do easily this? I Tried rove across time but that did not work accurately enough. I need the keys to fall exactly on the frame. Thanks.
    Mihai Wilson replied 17 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
