Activity Forums Adobe After Effects Change FPS rate without changing speed
  • Change FPS rate without changing speed
    Posted by Joaquín Gallo on June 23, 2014 at 6:34 am
    Hi!
    I have this problem: I filmed a video in 50fps but i need it in 29,97. ¿Why i filming in 50fps? Because in canon i cant film in 29,97 and i need edit two videos in the same comp.
    It’s possible change 50fps to 29,97 without change speed?
    Thanks a lot!
    Todd Kopriva replied 12 years, 2 months ago 3 Members · 5 Replies
  • Todd Kopriva
    June 23, 2014 at 7:01 am
    Just interpret your footage as the frame rate in which you shot it and create a composition at the frame rate that you want.
    Frame blending can take care of interpolated frames.
    Learn more here:
    https://www.video2brain.com/en/lessons/frame-rates
    After Effects team blog
  • Bhavesh Jadav
    Hi Joaquin,
    Import your footage in your project panel.
    Right click on your footage>Interpret footage>Main.
    There you can change your frame rate to whatever you want.
  • Joaquín Gallo
    June 23, 2014 at 7:16 am
    Thanks Bhavesh for the answer.. I do it, but that change the duration of the video.
  • Bhavesh Jadav
    June 23, 2014 at 10:14 am
    Hi Joaquin,
    Try this, Drop your 50 fps footage in new comp.
    Then make a new comp of frame rate 29.97 fps.
    In that 29.97 fps comp add your 50 fps footage comp(not the real footage). This should work fine.
  • Joaquín Gallo
    June 23, 2014 at 12:55 pm
    Works, Thanks a lot!! SOLVED!
