Activity Forums Adobe Premiere Pro change focus from keyboard…
  • change focus from keyboard…
    Posted by Alex Udell on June 23, 2005 at 8:53 pm
    Hi Again…
    Hate to be a pain…
    how do switch focus from source to record from the keybaord? (edit used the N key and Avid uses the Esc key)
    Every time I lay an edit and want to review…seems I have to click the record side (or timeline) with the mouse to make it pactive before reviewing…
    I’m not complaining….just want tknow if I can make it faster?
    Thanks…
    Alex Udell
    lead demo artist and trainer
    PEI Graphic Technology http://www.profileeast.com
    My Reel: https://alexudell.no-ip.biz
    COMBUSTION EXCHANGE FTP: ftp://combustionexchange.no-ip
    Logon: combustion_user
    PW: learn
    R. Hewitt replied 21 years, 2 months ago 5 Members · 9 Replies
  • 9 Replies
  • Craig Howard
    June 23, 2005 at 9:18 pm
    I have asked a similar thing everywhere and eventually put in a feature request for it. In my case I would like to toggle from Source Window to Timeline Window. Your preference would work for me just as well.
    The keyboard shortcuts should allow the user to direct (toggle) focus to the window of choice.
    Good luck.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • T-
    June 24, 2005 at 8:07 am
    CTRL + ~ is default use keyboard customization to set however you want
  • R. Hewitt
    June 24, 2005 at 12:14 pm
    The easiest option for switching between Source/Timeline I’ve found is Ctrl + Tab… as long as you don’t have too many windows open in PPro.
  • Alex Udell
    June 24, 2005 at 3:46 pm
    These Are great!!!!
    Thank YOU!!!!
    Alex Udell
    PW: learn
  • David J
    June 24, 2005 at 6:15 pm
    You’ll find a very useful list of PPro keyboard shortcuts at https://siliconbaymedia.com/permiere-pro-1-5-keyshortcuts-v2a.pdf
  • Craig Howard
    June 24, 2005 at 9:31 pm
    Problem with those shortcuts are they Cycle through the open windows. They do not toggle back and forth as per my workflow.
  • David J
    June 24, 2005 at 10:36 pm
    Adding SHIFT reverses the direction of CTRL+TAB, which helps.
    Have you tried using Keyboard Customisation to generate specific shortcuts for each relevant entry in the Window list?
  • T-
    June 28, 2005 at 2:09 am
    If you don
  • R. Hewitt
    June 28, 2005 at 3:25 pm
    I don’t think anyone was disseminating mis-information t-, the posts appear in the order they’re published and not necessarily in direct response to your original post.
