Activity Forums Adobe After Effects Expressions Change floor position in Bounce expression
  • Change floor position in Bounce expression
    Posted by David Rodriguez on May 14, 2008 at 10:21 am
    Darby Edelen and Dan Ebberts helped me cobble this expression together and now I need to modify it in the following way.
    I need the ball to bounce ONCE on the floor then I need the floor to fall away. I have tried tying the floor to an expression slider and animating it at the point where I need the change to happen, but this affects the whole animation and just sends the ball hurtling downwards. I just need the floor to act as if it isn’t there on the second bounce.
    Any help is much appreciated.
    With many thanks,
    David
    Vy0 = 200; //initial y velocity (pixels/second)
    seedRandom(index,true);
    Vx0 =random(-200,200); // initial x velocity (pixels/second)
    g = 2500; // gravity (pixels/second/second)
    floor = 1050;
    e = .82; //elasticity
    b = floor – position[1];
    h = b + Vy0*Vy0/(2*g);
    T = Vy0/g + Math.sqrt(2*h/g);
    if (time < T){ y = Vy0*time - g*time*time/2 + b; }else{ Vy = -(Vy0 - g*T); while (true){ Vy *= e; t = T; T += 2*Vy/g; if (time < T){ t = time - t; y = Vy*t - g*t*t/2; break; }else if (T - t < thisComp.frameDuration){ y = 0; break; } } } [position[0] + Vx0*time, floor - y]
    David Rodriguez replied 18 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 14, 2008 at 1:19 pm
    Try this:
    floor = 1050;
    if (time < T){ y = Vy0*time - g*time*time/2 + b; }else{ Vy = -(Vy0 - g*T); Vy *= e; t = time - T; y = Vy*t - g*t*t/2; } [position[0] + Vx0*time, floor - y] Dan
  • David Rodriguez
    May 14, 2008 at 7:27 pm
    This looks great, thank you.
    Now of course I need the balls to bounce twice not just once before the floor falls away.
    Help please!
    Con Muchas Gracias!
    David
