Activity Forums Apple Final Cut Pro Legacy Change files OS X LM
  • Change files OS X LM
    Posted by Juan Castillo on April 20, 2010 at 1:55 pm
    Hi all :
    I have a big problem , Download images of a p2 and I have some clips that are in xlm format and I can not open
    What is the problem ? I am novice in this matter of Final Cut and I find . The Final Cut I have is the Final Cut Pro 6.06 . If anyone can help me send me an email porfa juancastillo.Silvera @ gmail.com thanks
    Craig Thomas quinlan replied 16 years, 3 months ago 2 Members · 1 Reply
  • Craig Thomas quinlan
    April 21, 2010 at 1:07 am
    Do you mean XML? MXF perhaps? That would make a lot more sense…
    Did you use Log & Transfer in FCP for the P2 media? You have to retain the folder structure of the P2 media to be able to work with it. Sounds like you may have changed the folder structure or are trying to open individual files in the folder without properly transferring them.
    Use Log & Transfer to properly pull your clips in. It really isn’t any more complicated than that.
