Activity Forums Apple Final Cut Pro Legacy change field dominance
  • change field dominance
    Posted by Patrick Kofler on October 19, 2006 at 8:14 am
    hi guys,
    I’ve got to edit DV footage and 8bit uncompressed (bmd) footage onthe same timeline. The problem is the field dominance, which is different in DV and uncompressed files. What possibilities do I have? Can I somehow change the field dominance in the uncompressed material; the timeline 95% DV material.
    Patrick
    Nick Price replied 19 years, 11 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    October 19, 2006 at 4:13 pm
    If it were me, I’d just recapture the 8 bit AS DV… your blackmagic product can do this probably… or you can take the video from your beta? deck and send it thru a DV camera/deck and do it that way.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Roth weiss
    October 19, 2006 at 4:45 pm
    [Patrick Kofler] “The problem is the field dominance, which is different in DV and uncompressed files.”
    Patrick,
    Where are you located? In the NTSC world DV and 8-bit uncompressed are both lower field first.
    DRW
  • Patrick Kofler
    October 19, 2006 at 7:10 pm
    hi,
    as you can imagine, I’m located in the PAL world. To answer also the other suggestion, I could recapturn it as DV, but guys, there is to much difference in image quality. I’ve done it and made a test with exactly the same frame, DV and uc; well, it’s two different worlds. I know it may sound strange, but since the image quality of the beta tape is not the best (there is a lot of noise, becasue of more than one copy generation, I suppose), I cannot capture it with a codec which heavily compresses. I have to get out the maximum out of the material and therefore use an uncompressed codec.
    Patrick
  • Nick Price
    October 20, 2006 at 12:28 pm
    Hi Patrik,
    I would use media manager to recompress your 8bit footage to DV, using exactly the same file names for each clip. Edit with this ‘offline version’. Then when finished, reconnect your 8 bit clips with the original uncompressed files. This is your final ‘online’ version. Pretty standard way of working now.
    cheers
    NIck
