Activity › Forums › Adobe Encore DVD › Change encoder to CCE, is possible?
  • Change encoder to CCE, is possible?
    Posted by Luca Carlomi on March 19, 2010 at 3:25 pm
    Hi, I would like to encode my 20GB uncompressed DV AVI video with CCE SP2, but I can’t select it in the Encore CS4 options, nor in Adobe Media Encoder.
    I would prefer not to use the default CCE interface (the final file size isn’t even accurate).
    If I need another software, how can I automatically make the video size to fit perfectly on a DVD5 (having already encoded the audio in AC3 Dolby Digital)?
    Thanks in advance!
    Jon Geddes replied 16 years, 6 months ago 2 Members · 1 Reply
  • Jon Geddes
    March 23, 2010 at 6:19 pm
    Try HC Encoder. It’s free, and the quality is just as good, and sometimes better than CCE.
    You will need AVISynth to load your video though… not too big of a deal. Just install it, create a new .AVS file in the same directory as your video, edit it in notepad, and just add a quick script:
    AviSource(“uncompressed_master.avi”)
    Thats it. Then just load the .avs file into HC Encoder. There are a few more settings in the program, but it should be pretty straight forward.
    Jon Geddes
    http://www.precomposed.com
