Activity Forums Apple Final Cut Pro Legacy change efffect for multiclip angel edit..
  • change efffect for multiclip angel edit..
    Posted by Stefan Kroesbacher on December 6, 2005 at 2:33 pm
    i wonder how to change the effects of an multiclip angle,
    AFTER having done the edit…
    if i drag the effect over the clip in the timeline it affects only this clip.
    if i aplpy a filter to the sourcefile i made the multiclip with, nothing happens..
    if i collapse the edit – the same…
    what can i do??
    it’s a rather long edit (2h) so i don’t want to drag the
    filter to each little edited portion….
    thanx for any help..
    regards
    stefan
    Andy Mees replied 20 years, 9 months ago 2 Members · 1 Reply
  • Andy Mees
    December 6, 2005 at 3:15 pm
    sadly Stefan
    you are trying to shut the gate AFTER the horse has bolted.
    what you should have done is apply the effiect to the angle before youe edited with it … now you are limited to applying it clip instance by clip instance.
    now you are limited applying the effect to one instance of the angle, in the timeline, copying that clip, then multiple selecting all other instances of that angle in the timeline and using “Paste attributes” to copy the filter to all those other instances
    a learning experience!
    hopefully others will chime in with a quicker / more convenient way to help you
    good luck
    Andy
