Activity › Forums › Apple Final Cut Pro › change duration not working?
  • change duration not working?
    Posted by Kyrina Bluerose on November 2, 2018 at 9:13 am
    selecting a clip
    yellow selection box
    ctrl+d
    or right-click select change duration
    not working. not even turning purple, won’t accept numbers.
    I can trim, and I can ctr+opt+r and enter number there but that takes longer…
    any fixes?
    Kyrina Bluerose replied 7 years, 10 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    November 3, 2018 at 5:12 pm
    How are you selecting the clip? Use ‘c’ and not ‘x’ to select a clip
  • Kyrina Bluerose
    November 3, 2018 at 8:56 pm
    selecting clip in timeline – I usually just click on it.
    it worked before I updated and now it doesn’t.
  • Jeremy Garchow
    November 3, 2018 at 9:03 pm
    First, see if you have some sort of custom keyboard preset selected (under Final Cut Pro > Commands menu).
    Check to see if control-d is mapped to something else (or not mapped to Change Duration)
    If that doesn’t work, try trashing your preferences by quitting FCPX, and then hold command-option while you launch FCPX.
  • Kyrina Bluerose
    November 4, 2018 at 4:16 am
    Brand new FCPX; not sure why it didn’t work but that fixed it. Can’t imagine how much more slowly the work would go without control d.
