Activity › Forums › Adobe After Effects › Change dot with comma
  • Change dot with comma
    Posted by Michael Davydov on May 5, 2014 at 5:59 pm
    I have a simple code, showing an animated Slider number in a text field. It is a number with a floating point, like 29.3. And now I was asked to replace DOT with COMMA, to make it look like 29,3, and I don’t know how to do it.
    What is the right way to replace dot with comma in that matter?
    Thanks.
    Declan Smith replied 12 years, 5 months ago 2 Members · 1 Reply
  • Declan Smith
    May 5, 2014 at 7:20 pm
    Use the replace method of the string representation of the number.
    For example:
    numStr = “” + 12.35
    numStr.replace(“.”, “,”)
    So if your text field is something like:
    thisComp.layer(“Control”).effect(“Slider Control”)(“Slider”)
    Change it to read
    numstr=”” + thisComp.layer(“Control”).effect(“Slider Control”)(“Slider”).value;
    numstr.replace(“.”,”,”);
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
