Activity Forums Adobe Premiere Pro Change default key for snapping?
  • Change default key for snapping?
    Posted by Wesley Post on July 17, 2017 at 5:43 pm
    So being that I am an Avid user at work and a Premiere user at home, I try to have key mapping that translates seamlessly between both. One of the most used hotkeys for me is obviously snapping, which in Avid is holding CMD, but in Premiere is holding SHIFT. I would like to change the Premiere setting for it, but for the life of me I cannot figure out how. The only setting I found was “Snap,” which simply turns the snapping function on or off, and has nothing to do with the actual hotkey to use it. Thoughts?
    Wesley Post replied 9 years, 1 month ago 2 Members · 3 Replies
  • Wesley Post
    July 19, 2017 at 5:16 pm
    Surely there is a way to do this?
  • Joe Barta iv
    July 24, 2017 at 6:13 pm
    If you are using a Mac, go to the PremierePro CC top menu and select Keyboard Shortcuts (Option/alt + Command + K) to change the options.
    Type SNAP in the search window there to see if any of those listings are what you’re looking for.
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Wesley Post
    July 24, 2017 at 6:44 pm
    Thank you for the reply Joe, but as I pointed out, I have already tried that and the only hotkey to change is “Snap,” which simply turns the snapping function on or off, and has nothing to do with the actual hotkey to use it. I am still at a loss for how to remedy this.
