Activity Forums VEGAS Pro Change default interlace method in Project Properties
  • Change default interlace method in Project Properties
    Posted by Cedric Divang on December 16, 2013 at 10:29 pm
    Hello,
    Is it possible to change the default interlace method in the Project Properties ? I want to set it to “Interpolate” because “Blend” is too blurry but everytime I open a new video, it defaults to “Blend” and sometimes I forget to change it 🙁
    Please help.
    Cédric.
    Cedric Divang replied 12 years, 9 months ago 2 Members · 2 Replies
  • Mike Kujbida
    December 16, 2013 at 10:50 pm
    File – Properties.
    Set things the way you want and check the box at the bottom of this window that says Start all new projects with these settings.
    Be advised that every new project will start with these settings so you might have to change them depending on your specific needs but it’s the only way I know to do what you want.
  • Cedric Divang
    December 16, 2013 at 10:59 pm
    Hi Mike, and thank you for your fast reply.
    I wish there were a better solution because all I need is just force Interpolate without touching the rest 🙁 But thanks anyways.
    PS : Isn’t there a plugin or somthing like that that could do this ?
