Activity › Forums › Adobe After Effects Expressions › Change colour base on expression slider value
  • Change colour base on expression slider value
    Posted by Andy Bryce on September 9, 2016 at 4:02 pm
    Hello All,
    I currently have a Radial Wipe connected to a number value. I have linked both of these up to an expression slider.
    This part works.
    I would now like to change the colour of the solid the radial wipe is revealing based on the number value.
    When the value is between 1 and 39 the color is red
    When the value gets to 40 the color changes from red to purple
    When the value gets to 70 the color from purple to green
    Alexandru Graur replied 4 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    September 9, 2016 at 5:02 pm
    Assuming you’ve applied a Fill effect to your solid, something like this probably:
    s = thisComp.layer("controls").effect("Slider Control")("Slider");
    if (s < 40)
    [1,0,0,1]
    else if (s < 70)
    [.5,0,1,1]
    else
    [0,1,0,1]
    Dan
  • Andy Bryce
    September 9, 2016 at 5:18 pm
    Works perfectly thank you!
    How can I change the colour of each to a particular HEX colour code?
  • Andy Bryce
    September 9, 2016 at 5:48 pm
    One other question.
    Can I add an expression to a text layer to change text based of the value.
    From – critical – weak – strong
    Thanks in advance
  • Dan Ebberts
    September 9, 2016 at 5:53 pm
    This would be one way:
    c1 = 0xff0000; // red
    c2 = 0x7f00ff; // purple
    c3 = 0x00ff00; // green
    function hexToFloat(c){
    r = ((c & 0xff0000) >> 16)/255;
    g = ((c & 0xff00) >> 8)/255;
    b = (c & 0xff)/255;
    return [r,g,b,1];
    if (s < 40)
    hexToFloat(c1)
    else if (s < 70)
    hexToFloat(c2)
    else
    hexToFloat(c3)
    Dan
  • Dan Ebberts
    September 9, 2016 at 6:07 pm
    This should work:
    if (s < 40)
    "critical"
    else if (s < 70)
    "weak"
    else
    "strong"
    Dan
  • Andy Bryce
    September 9, 2016 at 6:15 pm
    You have really helped me out I am extremely gratefulT
    Thank you!
  • Ben Christie
    March 28, 2019 at 10:44 pm
    Hi Dan,
    I know you gave this answer a long time ago but it has been extremely helpful.
    Wondering if you know any quick tips on how to make an actual transition between colors vs just immediately popping to the needed color?
    Thanks.
    Ben
  • Dan Ebberts
    March 29, 2019 at 12:07 am
    I guess it could be something like this:
    b = (c & 0xff)/255;
    return [r,g,b,1];
    if (s < 40){
    ease(s,0,40,hexToFloat(c1),hexToFloat(c2));
    }else{
    ease(s,40,70,hexToFloat(c2),hexToFloat(c3));
    Dan
  • Alexandru Graur
    March 23, 2022 at 12:14 pm
    <yt-formatted-string slot=”content” split-lines=””>Hello. </yt-formatted-string>
    <yt-formatted-string slot=”content” split-lines=””>Quick question:</yt-formatted-string>
    <yt-formatted-string slot=”content” split-lines=””>Is there a way to change the fill color with expression based on a number? Let’s say you want -20 to be blue, 0 to be light yellow/white and 50 to be orange.</yt-formatted-string>
    <yt-formatted-string slot=”content” split-lines=””>Thanks.</yt-formatted-string>
    <ytd-button-renderer aria-expanded=”false” noink=”” use-keyboard-focused=”” button-renderer=”true”></ytd-button-renderer><ytd-button-renderer aria-expanded=”true” noink=”” use-keyboard-focused=”” button-renderer=”true”></ytd-button-renderer>
