Change color value once a slider passes a given value.
Hello CC community,
I apologize in advance if some one else has already answered this question, but:
I need an expression that does the following:
If the value of a given property (in this case, a slider control) exceeds a certain value (for example, 75), then a separate color control value would switch from color 1 (white) to color 2 (red).Thank you in advance for your help with this.
-Jonathan
