Activity › Forums › Apple Final Cut Pro Legacy › change color on capture?
  • change color on capture?
    Posted by Tad Newberry on January 30, 2006 at 5:39 pm
    i had thought there was a way to do some color correction as you capture, well, really, i mean set up the correction settings BEFORE capturing, but during the logging process, but nothing seems available, at least not with the DV capture settings. what up?
    thanks for helping out a bonehead,
    jtn
    Kevin Monahan replied 20 years, 8 months ago 3 Members · 3 Replies
  • Jeff Carpenter
    January 30, 2006 at 6:02 pm
    DV over firewire? Nothing can be changed. It’s just making a digital dub of the data on the tape. It’s pretty much the same as if you were copying a file off of a CD. There’s no way to alter the data as it’s being copied.
    You’d need some kind of capture card that is importing and digitizing the video as you go. Some of them can do stuff like that but you’ll have to wait for someone with more knowledge than me to advise you on that.
  • Tad Newberry
    January 30, 2006 at 7:55 pm
    no, this is through my capture card from a Beta tape. capturing in DV codec for an offline edit to save space.
    jtn
  • Kevin Monahan
    January 30, 2006 at 8:37 pm
    It’s usually possible to alter color on capture in composite, not component using a capture card.
    You’ll also need to work in another capture preset besides NTSC DV, as you can’t capture composite with that codec.
    A non-firewire based codec, like Apple 8 Bit will allow you to do this.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
