Activity Forums Avid Media Composer change color of AMA clips….
  • change color of AMA clips….
    Posted by Larry Tempesta on September 7, 2011 at 8:28 pm
    Is there anyway to change the color of the ama clips when imported? It comes in as all yellow and the only way to read the clip in the bin is to high light it….it’s extremely aggrivating. There’s gotta be a way to change it…
    Khoren Mirzakhanian replied 14 years, 12 months ago 3 Members · 2 Replies
  • John Pale
    September 7, 2011 at 8:38 pm
    Not that I can see. However it is possible to change the background color of your bin to make it more readable.
    Thats what I have been doing. But damn, its annoying…especially if you use a dark interface, like I do.
  • Khoren Mirzakhanian
    September 7, 2011 at 10:39 pm
    I havnt tried with AMA bins, but under “EDIT” menu all the way at the bottom there are “SET FONT” and “SET CLIP COLOR” options.
    see if that helps you out
