Activity Forums Adobe After Effects Expressions Change Color In layer order every 5 frames
  • Change Color In layer order every 5 frames
    Posted by Josh Boyd on March 17, 2020 at 5:32 pm
    I have a composition with close to 200 layers, and i want to make it where the color changes from a dark blue to a red. I was looking for an expression i could just copy and paste to all layers.
    I dont know expressions super well, but basically an expression that gets the layer number and multiplies it by 5 to get the frame it is supposed to change at. I want the transition from the color to color to be about 10 seconds. Is this possible? Or is this too much?
    Thank you so much!
    Josh Boyd replied 6 years, 5 months ago 2 Members · 5 Replies
  • Andrei Popa
    March 17, 2020 at 6:17 pm
    This should work.
    Replace the hex numbers between quotes with the hex number of your colors.
    linear(time,index*5,index*5+10,hexToRgb("FF0000"),hexToRgb("000000"))
    Andrei
    My Envato portfolio.
  • Josh Boyd
    March 17, 2020 at 6:23 pm
    This is what I am sort of looking for, except could it be every the 5 sec be every fifth frame and the duration be 10 frames instead of 10 sec.
    Thank you so much!
  • Josh Boyd
    March 17, 2020 at 6:32 pm
    I think i figured it out, as i am slowly learning this expression language.
    I just change time to timeToFrames(time)?
  • Andrei Popa
    March 17, 2020 at 7:17 pm
    Close!
    But this is the expression you need.
    linear(time,framesToTime(index*5),framesToTime(index*5+10),hexToRgb("FF0000"),hexToRgb("000000"))
    Every expression in After Effects calculates time in number, not frames. The 15th frame in a 30 fps composition is a 0.5 time. For example framesToTime(15) turns the number 15 into a 0.5 in a 30 fps composition. That is exactly the kind of transformation you need.
    Andrei
  • Josh Boyd
    March 17, 2020 at 9:19 pm
    Thank Andrei, I love when people explain it. It helps me understand how it is happening so i can learn more.
