Activity Forums Apple Final Cut Pro Legacy change clip speed without affecting other clips
  • change clip speed without affecting other clips
    Posted by Michael Garske on February 9, 2008 at 1:49 am
    Hi I am changing the speed of clips in the timeline. However, whenever I do this the other clips ahead of the one I’m changing move back the duration that the clip is shortened.
    How can I change clip speed using apple J without affecting the position of the other clips in the timeline?
    One other question is how do I use the option drag shortcut in the timeline without splitting the underlying audio track where I drop the copied clip.
    Thanks so much for your reply this will help me tremendously.
    Mike
    Kevin Monahan replied 18 years, 6 months ago 3 Members · 4 Replies
  • Miklos Philips
    February 9, 2008 at 2:13 am
    1st question: FCP does that because it’s the logical thing to do. Usually with speed changes on a single clip one has to “lift” the clip above into another track, lock the track in the timeline where most of your edits are – do your speed change on your clip on that new video track (so it doesn’t affect any other clip), adjust your in-n-outs on this speed-changed clip and drop it back in where you want it.
    2nd question, not really sure what you’re getting at here, but sound like a lot of this can be accomplished by locking your tracks and unlinking your audio files, so I would experiment with that.
    Point Zero Pictures
    <https://www.pointzeropictures.com>
  • Kevin Monahan
    February 9, 2008 at 7:05 pm
    The way I do it:
    1. Speed Change
    Match Frame-loads the clip back into the viewer.
    Apple + J to change speed.
    Replace Edit to put the speed affected clip into the timeline without rippling.
    Keep in mind that this changes the speed of the master clip. Not a problem unless you use the clip again. If so, just use Apple + J to change it back.
    2. To avoid an an insert edit when option + dragging, lift up on the option key before dropping. This changes your move to an overwrite instead of insert.
    Hope this helps you.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Michael Garske
    February 15, 2008 at 2:02 am
    wow thats great man! I knew it would be something simple. I was wondering about the option drag copy as well. Thanks for the tip.
    Mike
  • Kevin Monahan
    February 15, 2008 at 5:54 pm
    You’re welcome brother!
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
