Activity Forums Apple Final Cut Pro Change clip height shortcut
  • Change clip height shortcut
    Posted by Bret Williams on July 14, 2012 at 6:45 am
    In the keyboard commands, it says that there are hot keys for clip height. cmd+shift+”=” to increase, and cmd+shift+”-” to decrease. But neither do anything. Anyone know how to use these or get them to work?
    John Hepworth replied 11 years, 5 months ago 4 Members · 4 Replies
  • Neil Sinclair
    July 14, 2012 at 9:14 am
    As far as I can tell the Cmd + Shift shortcut only works when resizing clip thumbnails
    in the event browser whilst in Filmstip view. I’m using the ‘minimise’ with Roles
    in the timeline index to adjust track heights in the timeline. Not perfect but it definitely helps!
  • Jason Brown
    July 14, 2012 at 3:42 pm
    [Neil Sinclair] ” I’m using the ‘minimise’ with Roles”
    I use this as well…but I’m confused that it doesn’t seem to affect clips in the primary or secondary storylines?
    This seems like an oversight…I want to minimize everything. I rather like doing this by roles…I can work on tweaking VO levels…then minimize all VO. It’s pretty slick. (unless it’s in a storyline! 🙂 haha…
  • Bret Williams
    July 14, 2012 at 5:21 pm
    Looks like it. Well that’s moronic. In 7 I use shift+T all the time to toggle heights.
  • John Hepworth
    March 23, 2015 at 5:46 pm
    You can map ‘clip appearance – increase/decrease waveform size’ to something convenient.
    John Hepworth
