Activity Forums Adobe After Effects Expressions Change checkbox True/False with a button (if/else?)
  • Change checkbox True/False with a button (if/else?)
    Posted by Vincenzo Imbimbo on September 7, 2022 at 4:03 pm
    Hi guys, i’m trying to create a button that when you click it a checkbox would change it’s state, if its “false” then it will change to “true”, and if it’s “true” then it will change to “false”. I got it working but the problem is that only works once, then no longer changes, i want it to change everytime i press the button, what am i doing wrong?
    This is the code:
    myButton.onClick = function(){
    app.beginUndoGroup("myScript");
    var myLayers = comp.selectedLayers;
    for (var i = 0; i < myLayers.length; i++){
    myLayers[i].effect("APC Colorama").property(12).setValue(false)
    ? myLayers[i].effect("APC Colorama").property(12).setValue(false)
    : myLayers[i].effect("APC Colorama").property(12).setValue(true);
    app.endUndoGroup();
    Vincenzo Imbimbo replied 4 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 7, 2022 at 4:35 pm
    I haven’t tested this, but it seems like you’d want to do it this way:
    myLayers[i].effect("APC Colorama").property(12).value
  • Vincenzo Imbimbo
    September 7, 2022 at 4:48 pm
    MY GOD, you are a life saver Dan! Thank you so much.
