Activity › Forums › Adobe Premiere Pro › Change center of a clip?
  • Change center of a clip?
    Posted by Steve Brame on June 20, 2012 at 2:48 pm
    The Basic 3D effect rotates the clip on it’s center axis. However, cropping that clip off center cause the rotation to appear to be off-center, even though it’s only still rotating on the un-cropped clip center. Is there any way to move the center registration so that a off-center cropped clip rotates on the new center?
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
    Alex Udell replied 14 years, 3 months ago 3 Members · 5 Replies
  • Alex Udell
    June 20, 2012 at 4:23 pm
    How are you doing the cropping?
    Alex
  • Steve Brame
    June 20, 2012 at 7:15 pm
    Just using the Crop effect.
    Steve Brame
  • Kevin Monahan
    June 20, 2012 at 7:42 pm
    Adjust the anchor point.
    1. Open the clip in the Effect Controls tab.
    2. Click on the “Motion” parameter. The wireframe and anchor point will now be visible.
    3. Adjust the anchor point controls to place it where you want.
    4. Reframe the clip, as desired.
    Rotation, scale, etc. will be be affected according to the new anchor point.
    Anchor Point: https://help.adobe.com/en_US/premierepro/cs/using/WSC7A162B6-6EF1-49e1-8622-8127366710BB.html
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Steve Brame
    June 20, 2012 at 10:10 pm
    Sorry…should have mentioned that I’d already tried moving the anchor point. The ‘Swivel’ action of the Basic 3D effect seems to ignore that, and still swivels on the actual center of the clip…not on the new anchor point.
    Steve Brame
  • Alex Udell
    June 21, 2012 at 1:35 pm
    Steve,
    1) Crop your clip as desired
    2) Change the position of the cropped clip so that it’s centered in frame
    3) Right Click and nest that clip
    4) Add your Basic 3d to the nest clip on the timeline
    now you should be able rotate properly….
    Alex Udell
    Editing, Motion Graphics, and Visual FX
