Activity Forums Adobe After Effects change AE’s Timestep default?
  • change AE’s Timestep default?
    Posted by Sergio Juyak on May 25, 2013 at 11:25 pm
    I have asked this question before and never found a solution. I’m working in a 25fps project and the 10-frame ‘ctrl-shift-rightarrow’ shortcut is prettymuch useless because it doesn’t divide easily into 25fps comp time. I want to change the prefs file to jump in 5frame increments (instead of 10). I can find the shortcut in the shortcuts file, but can’t find ANYTHING in the prefs file. I searched for ‘step time’ ‘time’ ‘ctrl-shift’ etc and no dice. Is it possible to change this? Below is a section of the shortcuts file.
    [“CCompTime”]
    “TimeFastForward” = “(Ctrl+Alt+RightArrow)(END)”
    “TimeJumpToIn” = “(I)”
    “TimeJumpToNextInOut” = “(Ctrl+Alt+Shift+RightArrow)”
    “TimeJumpToOut” = “(O)”
    “TimeJumpToPrevInOut” = “(Ctrl+Alt+Shift+LeftArrow)”
    “TimeJumpToWAEnd” = “(Shift+END)”
    “TimeJumpToWAStart” = “(Shift+HOME)”
    “TimePlay” = “(Space)”
    “TimeRewind” = “(Ctrl+Alt+LeftArrow)(HOME)”
    “TimeSetIn” = “([)”
    “TimeSetOut” = “(])”
    “TimeStepBack” = “(Ctrl+LeftArrow)(PageUP)”
    “TimeStepBackMore” = “(Shift+PageUP)(Ctrl+Shift+LeftArrow)”
    “TimeStepForward” = “(Ctrl+RightArrow)(PageDOWN)”
    “TimeStepForwardMore” = “(Shift+PageDOWN)(Ctrl+Shift+RightArrow)”
    “TimeStretchIn” = “(Ctrl+Shift+Comma)”
    “TimeStretchOut” = “(Ctrl+Alt+Comma)”
    “TimeTrimIn” = “(Alt+[)”
    “TimeTrimOut” = “(Alt+])”
    Sergio Juyak replied 13 years, 3 months ago 2 Members · 2 Replies
  • Todd Kopriva
    May 26, 2013 at 4:59 pm
    No, there is no way to change this now. If you’d like a way to change it, submit a feature request here:
    https://www.adobe.com/go/wish
    After Effects team blog
  • Sergio Juyak
    May 26, 2013 at 8:01 pm
    Hey thanks for responding Todd. Much appreciated. Will do.
