Activity Forums Apple Final Cut Pro Legacy Change a sequences’ settings after an edit is made
  • Change a sequences’ settings after an edit is made
    Posted by Lucy Moon on February 14, 2007 at 11:22 pm
    Hi there,
    I am inheriting a project, shot in 16:9 DV but edited in a 4:3 sequence. I would like to make the sequence 16:9. How do I do this to an existing edit, it seems to squish the footage wrongly when I modify the sequence settings.
    thanks in advance.
    ~lucy
    (FCP 4.5 on a Mac G5)
    Enzo Tedeschi replied 19 years, 7 months ago 2 Members · 1 Reply
  • Enzo Tedeschi
    February 15, 2007 at 9:08 am
    Always dupe the sequence before you start mucking around with settings!
    Change the sequence settings to 16:9, then drag and select all the video clip son the timeline, opt-click Remove Attributes.
    This will bring up a dialog box, asking you which attributes to remove. Select Distort (from memory…) and apply. This should arc everything back to 16:9…
    Enzo Tedeschi
    ____________________________
    Editor
    http://www.outpostpps.com
    Sydney, Australia
    YouTube Channel – http://www.youtube.com/outpostpps
    Check out the Outpost Video Podcast – http://www.outpostpps.com/podcast/
