Activity Forums Adobe Premiere Pro Challenge with scan converted computer footage
  • Challenge with scan converted computer footage
    Posted by Steve Pender on February 6, 2014 at 2:11 pm
    Not sure if this is more appropriate for the Encore forum, but I’ll start here. I recently created a short video for a client that incorporated a computer screen showing the client’s software in action. The screen displays lots of small text, columns of numbers and some waveforms. I captured the output of the computer via it’s DVI output using an Image Pro scan converter. Capture was at 1920x1080p. I created the video in 1920x1080p using After Effects CS5 and Premiere CS5. I then created a Blu-ray and a DVD using Encore CS5. On the Blu-ray, I think the computer screen looks great. My issue is with the DVD. I outputted an MPEG2 DVD file, first at CBR8 and then CBR 9. On DVD, the computer screen suffers considerably. Much softer and hard to read the on-screen text. I realize I’m downscaling quite a bit, but I’m wondering if there’s any way I can get a better image? The piece runs just 3 min 45 sec, so I have lots of room on the DVD. Any and all suggestions would be appreciated. Thanks in advance.
    Steve Pender
    Family Legacy Video, Inc.
    https://www.familylegacyvideo.com
    Jon Doughtie replied 12 years, 7 months ago 2 Members · 1 Reply
  • Jon Doughtie
    February 6, 2014 at 5:29 pm
    Not only are you downscaling resolution, you are going from progressive to interlaced. As long as you want it compatible with DVD players, there’s a limit to how much you can do.
    One thing I would look at is re-capturing the footage for the DVD version with the computer set to a lower resolution; even as low as 640×480. Depending on the software, that may be an issue as well. It would also require a re-edit for the DVD version. But with reduced downscaling from the original, you may get a better result for DVD.
    You’ll still have to endure the difference between progressive and interlaced, though.
