Activity › Forums › Maxon Cinema 4D › Chain Fence
  • Adam Trachtenberg
    August 15, 2009 at 3:43 am
    I haven’t modeled one, but you should be able to do it by creating a single spline/sweep, mirroring it, and then duplicating it MoGraph or the standard duplicate function. The trick would be twist at the top. I’d try using a twist deformer for that.
  • Richard Gardner
    August 15, 2009 at 7:43 pm
    Thanks, Adam.
    I have been trying to do this with a helix in a sweeps nurb. I’ll try your tip using a mograph.
