Activity › Forums › Apple Final Cut Pro Legacy › Chaging Parameters in MB Looks Filter
  • Chaging Parameters in MB Looks Filter
    Posted by Sascha Engel on October 17, 2009 at 3:49 pm
    I have following problem – I use MB Looks in FCP for giving a look to a 60min Feature Film. I am mostly finished with the Grading. Now I want to change one feature – the TELECINE effect value inside my look. How can change that vvalue inside the looks of multiple clips at the same time (e.g. Pasting Attributes) without opening each edit state of each Look Filter in each clip seperately?
    Helps appreciated a lot.
    Thanx!
    Greetz,
    Sascha
    Sascha Engel replied 16 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    October 17, 2009 at 4:20 pm
    Hi Sascha,
    Yes, paste attributes> filters. But before you have to remove the old filter from the clips.
    Be careful, you can paste or remove filters that you don’t want to.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Sascha Engel
    October 17, 2009 at 4:24 pm
    HI Rafael,
    the problem here is following: I want to just change one parameter inside the MagicBullet Looks Filter – in this case the value of the TELECINE percentage, not the replace the whole filter itsself – for that other values in different shots have different numbers. Anyway, that I can replace just that single value inside the Look Filter?
    Thanx
  • Rafael Amador
    October 17, 2009 at 4:27 pm
    I understand there are other parameters that you want to keep different.
    I’m afraid there is no way.
    rafael
  • Massimo Croce
    October 17, 2009 at 9:41 pm
    try to export as xml, and then modify the file in a text editor (eg. text wrangler). find the parameter mane and modify. in a text editor is simple to find a and modify many string at once. reimport the new file.
    Massimino Croce
    Senior editor
    NEW VIDEO PROJECT
    Rome Italy
    https://www.newvideoproject.it
  • Sascha Engel
    October 18, 2009 at 11:31 am
    Sounds worth trying! THANX a lot. Where do I get such an editor from for MAc, or I can use a standard text editor in Mac OS?
    Greetz,
    Sascha
  • Massimo Croce
    October 20, 2009 at 7:48 am
    https://www.barebones.com/products/TextWrangler/ it s free and good editor
    Massimino Croce
    Senior editor
    NEW VIDEO PROJECT
    Rome Italy
  • Sascha Engel
    October 20, 2009 at 9:09 am
    Thanx a Lot!!!!
