Activity › Forums › Adobe After Effects Expressions › CEP Panel: Event Listener Layer Selection
  • CEP Panel: Event Listener Layer Selection
    Posted by Malte Hillebrand on March 20, 2020 at 2:57 pm
    Hey, I’m fairly new to plugin creation in Adobe products / After Effects and I’m hoping you can help me.
    I’m trying to create an event via CSInterface whenever a layer is selected within a comp.
    I then want to adjust my HTML5 Panel accordingly to the selected layer.
    Is this possible and if so, how?
    I couldn’t find anything about this behaviour.
    Also: If somebody has any link to a good ressource for CSInterface.js and it’s communication with After Effects and my panel I would highly appreciate it.
    Thank you.
    Mahmoud Elsafy replied 5 years, 2 months ago 3 Members · 2 Replies
  • Andrei Popa
    March 24, 2020 at 10:25 am
    If you decide to create Script/Plugins for AE, you should get terminology correct.
    Script = program created in ExtendScript(JavaScript plus some additions to fit Adobe products). EcmaScript 3 standard.
    Extension = a script that works inside a web interface. I think you can use EcmaScript 6 inside the web part and EcmaScript 3 inside the script part.
    Plugin = a whole different league. Programmed in C++. You can access about anything in AE with those. But are much much more complicated than scripts or extensions.
    Now, for your answer.
    I don’t have much experience with Extensions but have a fair bit with scripts.
    And since an Extension is a script with web interface, I’m gonna take a wild guess and say no. I don’t think you can add things like layer.onSelect().
    If you are new to Extensions, this tutorial could help you understand how they work.
    https://www.youtube.com/watch?v=UXOvW659rek
    Andrei
    My Envato portfolio.
  • Mahmoud Elsafy
    July 28, 2021 at 3:09 pm
    Main .jsx
    function getSelectedLayer() {
    SL = app.project.activeItem.selectedLayers;
    //return selected layer index or any other property
    return SL.length != 0 ? SL[0].index : null
    main .js in HTML
    var csInterface = new CSInterface();
    setInterval(() => {
    csInterface.evalScript(“getSelectedLayer()”, function (result) {
    if (result !== “null”) {
    //Do something when layer is selected
    $(‘#elemID’).html(‘Selected Layer index: ‘+ result);
    }, 1000); // checks selected layer every one second
