Activity › Forums › Adobe After Effects › Center the Grids (not proportional grid) to comp?
  • Center the Grids (not proportional grid) to comp?
    Posted by Pär Söderlund on November 8, 2018 at 7:14 am
    Hi everyone, first post here.
    Since it seems impossible to snap to the Proportional grid (based on this post: https://forums.adobe.com/thread/2292091) I want to snap to the Guides, which works. The problem is, the guides are not in center! When I enter 192 in “Gridline Every” under Preference>Grids and Guides the length of the grid matches a 1920×1080 comp. But the high is of. Since the Subdivisions only decides how big the squares can be, I wonder – how can I make that grid fit perfectly in the comp like the Proportional grid?
    This would help my tremendously in my workflow. If not possible, is there a plugin that does exactly this? I have looked at these two and perhaps some of you know if they can solve my problem or just vouch for them to be a must have in the toolbox (please explain why)? ☺
    https://aescripts.com/gridguide-for-after-effects/
    https://lesterbanks.com/2018/03/move-anchor-point-4-ae/
    Cause another annoying problem I have is when the anchor point is not in the center, the align tool places the object, not the anchor point in the positions I want.
    All the best!
    /Pär Söderlund
    Pär Söderlund replied 7 years, 10 months ago 2 Members · 4 Replies
  • Kalleheikki Kannisto
    November 8, 2018 at 9:23 am
    Any of these grid spacings will divide evenly to those two dimensions (common factors of 1920 and 1080):
    1, 2, 3, 4, 5, 6, 8, 10, 12, 15, 20, 24, 30, 40, 60, 120
    60 sounds the most useful to you, both vertical and horizontal grid lines go through the center point.
    120 with 4 subdivisions isn’t too bad either.
    Senior Graphic Designer
  • Pär Söderlund
    November 9, 2018 at 7:00 am
    Wow! Thanks! Worked like a charm ☺
    Do you have a link to where you got that info? I wonder how the math is done.
    Is it possible to only get 9 or 18 squares that matches like the proportional grid (when that set to that amount)? In my head I want to enter 60×2 to get them bigger and it looks weird.
    November 9, 2018 at 9:37 am
    Hi Pär,
    You can find the common factors calculator here: https://www.calculatorsoup.com/calculators/math/commonfactors.php
    Those are the only integers that divide exactly, and 60 is the largest one that goes through the center point in both directions. You can do 120 with 2 subdivisions, but the end result is virtually the same: just every other line is thinner.
  • Pär Söderlund
    November 11, 2018 at 12:16 pm
    Thank you so much Kalleheikki!
    /Pär
