Activity Forums Adobe After Effects Expressions Center text layer based on words anchor points
  • Center text layer based on words anchor points
    Posted by Dagur Maunason on November 30, 2016 at 8:45 am
    I’m working on a lyric video for a rap track and would really need your help with an expression. I tried myself and searched around but to no avail.
    I have a text layer with a single line of text with its point group alignment set to words. What I want to do is move this layer sideways in steps lasting a few frames, so that each word is centered on stage briefly. Is it possible to do this using the words anchor points? It would save me a ton of time with so many lyrics ☺
    Thanks in advance!
    Dagur Maunason replied 9 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 30, 2016 at 5:50 pm
    You could probably work something up with scripting, but I think it would be impractical with an expression.
    With a script, you could add each word in sequence, measure the resulting size (with sourceRectAtTime()), and calculate the approximate center of each word. A bit of work though.
    Dan
  • Dagur Maunason
    November 30, 2016 at 6:24 pm
    Ok, thanks for your input Dan! I guess I will have to knuckle down for some serious keyframing then 🙂
