Activity Forums Maxon Cinema 4D Center gradient ripple + Octane Render
  • Center gradient ripple + Octane Render
    Posted by Noa Xavier on March 31, 2020 at 9:54 pm
    Hello everyone,
    Today I’m trying to achieve what seems like a simple effect but I haven’t had much luck with it.
    Here are my early ideas/concepts:
    Idea (Set selection + Fields)
    1. Start with a plane
    2. Set a polygon selection
    3. Enable ‘fields’
    4. Add ‘spherical field’
    result (1):
    https://ibb.co/mbrtyvq
    (Forum’s image upload is not working for me right now so hosting images here instead)
    Result 1: Not at all what I wanted, I was hoping that I would be able to control the expansion of the material unto the plane, instead it create an interesting pixel like effect, will save this for a more graphics project.
    Idea 2:
    I’m struggling with getting the effect to work on a plane, so let’s simplify and try cloners.
    1. Create clone > Object mode
    2. Insert sphere to plane polygon center
    3. Add spherical field and enable color remap
    Result(2):
    https://ibb.co/VMkjv9M
    This works for controlling the color of each clone through a gradient (Super cool) however it only renders in the physical render engine, when I try to render in octane the effect fails, I have tried to add an octane object tag but that did not work.
    Summary:
    I’m trying to achieve the ability to control the color of materials using fields. Essentially I’m trying to achieve this effect and render within octane.
    https://ibb.co/chCgscv
    https://www.youtube.com/watch?v=untLDcPPdsw
    00:1 – 00:2
    I can achieve this effect fairly simply in after effects but unsure how to go about it on C4D despite trying several options. Hopefully someone can shed a light on this.
    Cheers!
    Here is the file I have so far, though I doubt it would help very much:
    https://drive.google.com/file/d/18zvS88OQDVgv5N_yEzsCT_yfC_xx9VBE/view?usp=sharing
    Noa Xavier replied 6 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
