Activity Forums Apple Final Cut Pro Legacy Center Extraction
  • Center Extraction
    Posted by Benjamin Mckay on March 29, 2010 at 2:19 pm
    I have RED 1920×1080 23.98fps square pixel. I need to send to broadcast in SD. Can I leave the pixel square, or is there a best way to get the pixel to NTSC CCIR 601 without squishing the image. Also, it will not be letterboxed. Or, can I leave it square pixel, or is this a major no no.
    “Cult Of One”
    Benjamin Mckay replied 16 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    March 29, 2010 at 5:58 pm
    Do nothing. Edit normally, then output via a capture card that will do the center extraction. If you are using FCP 7, you can see that they guides now include 4×3 title and TV safe, so you can see where your image will be cut off.
    Just edit normally.
    Shane
  • Benjamin Mckay
    April 5, 2010 at 4:41 am
    Thanks man. I figured out what to do since i don’t have a the hardware card on my mac. i’m just going to take the project into my Smoke and down convert it there. it comes out awesome!
    “Cult Of One”
