Activity Forums Adobe After Effects Center en masse Text Layers’ anchor point?
  • Center en masse Text Layers’ anchor point?
    Posted by Eric Chard on December 16, 2012 at 9:56 pm
    I have many many Text Layers (programmatically generated) that I would like to have their Anchor Points centered.
    How might I do that en masse? (All at once?)
    “Putting the HARM in ‘harmonica’ since 2005.”
    Eric Chard replied 13 years, 8 months ago 2 Members · 2 Replies
  • Ridley Walker
    December 17, 2012 at 2:25 am
    To center to the layer both horizontally and vertically you could use the script from BatchFrame to move anchor points:
    Found here: https://www.batchframe.com/extras/
    Of course this requires you to select the layers (multiple if required) then apply the new anchor point.
    If you are using a script to generate the text layers (you did mention “programatically”) then why not set the anchor point in the script using the layer’s width and height divided by 2 to find the center?
  • Eric Chard
    December 17, 2012 at 6:36 pm
    Thanks for that pointer.
    It would be superior to alter the TEXT>>LAYERS script I’m using to generate the comp, but I’m very new at scripting and didn’t want to get embroiled in a big mess. Perhaps it’s very simple.
    THANKS!
