Activity › Forums › Avid Media Composer › center duration display 24 frames
  • center duration display 24 frames
    Posted by Patrick Murphree on August 11, 2009 at 11:02 pm
    Working in MC 3.0.5 on a Mac. Working in a 23.98 project. Digitized material off 29.97 dvcam tapes and removed pulldown. Set TC displays to show 24 TC, but seems that center duration still gives absolute frame count based on 30 fps. Am I wrong. How do I get it to display a 24 fps frame count?
    PM
    Job Ter burg replied 17 years, 1 month ago 2 Members · 2 Replies
  • Patrick Murphree
    August 12, 2009 at 12:39 am
    correction. the seconds and frames display shows a 30 fps frame count. the absolute frame count is correct.
    PM
  • Job Ter burg
    August 12, 2009 at 7:00 am
    Does it work if you toggle the upper Master TC display back and forth between 24 and 30? That used to help on Meridien systems when working in PAL.
