Activity Forums Adobe After Effects Expressions Center and Animate text position
  • Center and Animate text position
    Posted by Magno Alves on March 17, 2019 at 7:18 pm
    Hello, first of all, I want to thank those who contribute in this forum where I already had a lot of doubts about expressions in After Effects.
    I’ve tried a lot of how to make animation based on expression in both the forum and the internet and I did not find a solution.
    My question is this:
    I have to relate the following animation expression to the position of another layer?
    ease (time, inPoint + 0, inPoint + 1.5, [x, y], [x, y];
    I want to make the position of the text start and end based on the position of a solid. Please see the image link to understand a little better.
    https://media.giphy.com/media/1Qco37oaSMmAnb8koe/giphy.gif
    I am already the expression below to centralize the text:
    var w = thisComp.width;
    var h = thisComp.height;
    var w2 = w / 2;
    var h2 = h / 2 +50;
    [w2, h2]
    When the expression of movement is working can you integrate the two?
    Sorry for the poor translation.
    Thanks for the help.
    Magno Alves replied 7 years, 5 months ago 2 Members · 4 Replies
  • Scott Mcgee
    March 18, 2019 at 8:36 am
    If you don’t want to follow the solid this is how you do it.
    x = thisComp.width/2;
    ya = 0 – thisLayer.sourceRectAtTime().height – 50;
    yb = thisComp.height/2;
    ease (time, inPoint + 0, inPoint + 1.5,[x, ya], [x, yb]);
    if you want to follow the solid. Just pick whip the position to the solids position and it will copy the movement.
    But for both you need to centralise the anchor.
    r = sourceRectAtTime();
    [r.left + r.height/2, r.top + r.height/2];
  • Magno Alves
    March 18, 2019 at 2:33 pm
    Dear Scott McGee thank you very much for the tip, for some time I was looking for a solution to this animation.
    But I forgot to mention something important the solid is linked to the text by the expression:
    parent.sourceRectAtTime (). top -1098
    So when I implement your suggestion does not work because the solid moves along with the text as in the example below:
    https://giphy.com/gifs/6qq0BQAQBklFTPDMVC/html5
    What I want from this animation is for the solid to align to the top of the text when typing any number of lines and then it is fixed so that I can animate position of the text as I did in the example below using keyframes and without any expression.
    https://giphy.com/gifs/XJzx1kWwJkoddJXQKJ/html5
    Thanks for all the effort and help!
  • Scott Mcgee
    March 20, 2019 at 9:19 am
    I’ve just recreated what you’ve done in your second video example by doing this.
    anchorPoint
    [r.left + r.width/2, r.top + r.height/2];
    Position
    yb = 0 + thisComp.layer(“Shape Layer 1”).sourceRectAtTime().height + thisLayer.sourceRectAtTime().height/2 + 30;
    The position looks at the height of the shape layer + the height of your text/2 + a little padding. This proportions itself accordingly.
    It might need tweaking, but it looks the same as your 2nd video example.
  • Magno Alves
    March 25, 2019 at 6:32 pm
    Thank you all for your help! I am very happy to always come in the forum and find answer to all my doubts of expressions in the after effects.
