Activity Forums Maxon Cinema 4D Center an object’s axis, is there an easy way?
  • Center an object’s axis, is there an easy way?
    Posted by Simon Hutchinson on February 10, 2009 at 5:40 pm
    Hi there,
    I wonder if there is an easy way to center and objects axis using a short cut, rather that switching to axis mode (don’t know if that is the correct terminology?) and manually moving the axis to what I think is the objects center?
    Probably a simple fix I should have asked ages ago, instead of wasting time tweaking in the various viewports.
    Jethro.
    Brian Jones replied 12 years, 3 months ago 3 Members · 5 Replies
  • Brian Jones
    February 11, 2009 at 12:07 am
    Structure/Axis Center
  • Jessica Ma
    April 27, 2014 at 3:10 pm
    no such thing as structure in r14 u talking about a different version?
  • Brian Jones
    April 27, 2014 at 4:52 pm
    yeah that was 5 years ago, in 13+ it’s Mesh/Axis Center
  • Jessica Ma
    April 27, 2014 at 11:22 pm
    Thanks brian – off the cuff – do you happen to know if there is a tag in c4d that will make a light emitting plane emit light but not seen in the render? (kind of like the “not visible in render” flag in maya.
  • Brian Jones
    April 28, 2014 at 2:46 am
    Compositing Tag – uncheck ‘Seen By Camera’
