Activity Forums Adobe After Effects Expressions Center align a text box with a script.
  • Center align a text box with a script.
    Posted by Andrei Popa on December 21, 2016 at 4:25 pm
    I have a multitude of comps in which i have one char. I need to save the two anchor points of the char when it is LEFT_JUSTIFIED and RIGHT_JUSTIFIED. The char needs to be center aligned both times. It is initially LEFT_JUSTIFIED and in the center. But after i save the position and change the text to RIGHT_JUSTIFIED, i can’t figure out how to put the character back in the middle of the composition to be able to save the second value of the position. I can do this by clicking the “horizontal center alignment” and the “vertical center alignment” in the after effects interface, but due to the high number of comps i have, this is not really a solution. I appreciate your support.
    Andrei Popa replied 9 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
