Celluloid Film wrap on Spline path problems (file and picture)
I’m trying to create a smooth celluloid film path using an extruded vector I brought in from Ai of a piece of film, and then either trying to
1. Wrap the object around the spline, which works, but I can’t figure out how to duplicate the object so it covers the whole spline
2. Tried to use the cloner “Object” setting, and that works, except the film does not bend at the corners since it’s not wrapping around the spline
I tried a combination of the two, but couldn’t get the spline wrap deformer and the cloner to work together.
Any ideas? Trying to make it look sort of like this:
https://www.corbisimages.com/images/42-17764414.jpg?size=572&uid={2AF0716B-87F7-40D8-AF9A-2B5921743025}Image:
https://i.imgur.com/JIKpZ.pngHere’s the file R12:
https://www.mediafire.com/?b42p92t38n3hath
