Activity Forums Adobe After Effects Cellphone HUD tracking and perspective.
  • Cellphone HUD tracking and perspective.
    Posted by Michele Poggi on October 18, 2011 at 12:31 am
    I’m having problems with this HUD recostruction.
    The main problem I found is the tracking and perspective that, starting the job, I thought as quite easy and possible. I’m using the Corner Pin effect and I’ve tried every single thing that came to my mind to actually make it perfectly tracked to the real phone but there are issues.
    I even tried to track the four real corners of the screen and then link their positions to the corner pins in the Effects of the reconstructed HUD but somehow it gave me horrible results. The video shows my current situation: do you have any idea about how to make it stop trembling? I already had to correct the movements manually with dozens of keyframes.
    https://reels.creativecow.net/film/cellphone-hud-recostruction
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
    Angelo Lorenzo replied 14 years, 11 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    October 18, 2011 at 1:41 am
    I assume you’re using multiple point trackers?
    Use Mocha, it’s a program that comes in addition to After Effects. It’s a planar tracker so it’s used to track the perspective of an image plane (like a screen).
    Before diving into a bunch of online videos about Mocha, check out their help PDF file. Most of it is written as a step-by-step tutorial and even uses a cell phone screen for the main example.
    – Angelo Lorenzo
    An iPhone 4S tribute to Steve Jobs
    https://FilmsFor.Us Sell your film and connect with your audience
