Activity Forums Apple Final Cut Pro Legacy Cell phone buzz
  • Cell phone buzz
    Posted by Jason Djang on August 14, 2009 at 10:28 pm
    I’m editing an interview which has some of annoying interference from an incoming cell phone call. Anyone know the magic formula for EQing (or any other approach) for minimizing it? I can’t seem to find the right frequency. Or is something altogether different going on?
    Mark Maness replied 17 years, 1 month ago 6 Members · 5 Replies
  • Michael Harrington
    August 14, 2009 at 10:42 pm
    I can’t tell you exactly how to do it but look at Soundtrack Pro. I remember seeing a demo at NAB a few years ago and they were able to process out a walkie talkie that was squelching in the background, in that same demo they were also able to reduce and unwanted motorboat sound.
    Michael Harrington
    Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, ATI Radeon HD 4870, 30-inch Cine Display, 4TB internal, 1.25TB Esata, FW 800 external drives, AJA Io, SOny Multiformat Broadcast Monitor, Mackie 1402 & Event 20/20 monitors.
  • Ben Holmes
    August 14, 2009 at 11:19 pm
    You might have some joy with a band pass filter, if it’s different enough from the speech – it usually gets rid of some of the qualities of the interview record – in this case, it may make it sound muffled.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Tom Brooks
    August 16, 2009 at 12:44 am
    I’d try the noise reduction in Soundtrack Pro as a start. You find the bad sound in a gap between words. Highlight some of that and use Process/Noise Reduction/Set Noise Print. Then use Process/Noise Reduction/Reduce Noise and play with the settings. If it’s a narrow spectrum sound, it can work OK. You can also play with the spectrum display option to visualize the noise and attempt to edit it out. View/File Editor Display/Show Spectrum.
  • John Fishback
    August 16, 2009 at 2:38 am
    iZotopeRX https://www.izotope.com/products/audio/RX/
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Mark Maness
    August 17, 2009 at 3:40 pm
    That is the most impressive audio repair program that I have ever seen… WOW!
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
