Activity Forums Maxon Cinema 4D Cel Render or Toon Shader
  • Cel Render or Toon Shader
    Posted by Tim Monaghan on December 10, 2011 at 12:47 am
    Is it possible for the wire frame render to have perspective so that an edge up close has bigger lines than the background edges?
    Thanks for any thoughts on this.
    Tim Monaghan replied 14 years, 8 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    December 10, 2011 at 3:58 pm
    It’s possible witht Sketch and Toon. Just check the distance parameter in the sketch material’s thickness tab. You can set it to Object, Camera, etc.
  • Tim Monaghan
    December 10, 2011 at 10:01 pm
    That’s perfect! Thank you!
