Activity › Forums › Avid Media Composer › Cease Waveform Processing
  • Cease Waveform Processing
    Posted by Stephen Hill on January 4, 2016 at 4:40 pm
    How can I stop the processing of the visual audio waveform for a long clip that was been brought into the preview timeline?
    Nice to use the waveforms…but sometimes I forget to turn it off b4 i bring the clip in.
    thanks
    edit on
    Michael Phillips replied 10 years, 8 months ago 2 Members · 1 Reply
  • Michael Phillips
    January 4, 2016 at 8:47 pm
    What version are you running? I only use the waveform button on a per track basis that can be turned off or on and is defaulted to off when loading new sequence. If you uses the old waveform from the hamburger menu it stays active (I think, it’s been a while). I would set the setting to only show between marks then you can clear marks. Any operation is supposed to interrupt the waveform display process.
    Michael
