Activity › Forums › Adobe After Effects Expressions › CE Pixel Sampler Tutorial
Posted by Robert Mrozowski on August 24, 2007 at 6:40 pmI just viewed Jerzy Drozda’s Pixel Sampler Video Tutorial. It was great but I had a problem installing his animation presets that could be downloaded with the tutorial.
First off I must mention that I’m on a Mac.
The animation presets were no problem to drop into the After Effect Presets folder but when it came to adding the xml files to the PresetEffects.xml, I couldn’t find the Mac equivalent of that file.
Can someone tell me where to find it?
Jerzy Drozda jr replied 19 years, 1 month ago 4 Members · 11 Replies -
Kathlyn Lindeboom
August 24, 2007 at 7:05 pm[robertmro] “Can someone tell me where to find it?”
Did you read the instructions on the tutorial page? Just above where you download the presets?
Here they are again:
- Download Mac version of the package below.
Unpack it to a convenient place - Right click (or control-click) on the After Effects CS3 application name in your Application folder. choose ‘Show Package Contents’
- Navigate to the Resources folder and locate the PresetEffects.xml file. Make a backup copy of this file.
- Open PresetEffects.xml file in any text editor
- Open the XML file provided in the package that you
Robert Mrozowski
August 24, 2007 at 7:29 pmThanks Kathlyn, but the trouble is, there is no such file at that location.
How is that possible?
Kevin Camp
August 24, 2007 at 8:55 pmactually, he mentions that he assumes the mac file would be in a similar location, but could not be certain… have you tried ‘find?’
i was hoping to find that xml file to do some hacks of my own, i hope there is a mac equivalent….
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Kevin Camp
August 24, 2007 at 9:06 pmi found it, it is in the ae app package.
select the ae application and control-click (or right-click) and select show package contents. in contents/resources you’ll find the preseteffects.xml file…. modify and save.
Kevin Camp
Kathlyn Lindeboom
August 24, 2007 at 9:45 pm[moldyboot] “select the ae application and control-click (or right-click) and select show package contents.”
Is that not what I said?
Right click (or control-click) on the After Effects CS3 application name in your Application folder. choose ‘Show Package Contents’Kathlyn Lindeboom
The Mistress of Mmmooooo -
Kathlyn Lindeboom
August 24, 2007 at 10:01 pmThis is kind of hard to understand for us mac people — I know we’re not used to all these invisible files. Jerzy didn’t know and I searched long and hard for the instructions.
I’ve made a little graphic. Hopefully, this will help. I’ll also link it in to the tutorial page as well.
Here’s the graphic:
https://library.creativecow.net/articles/drozda_jerzy/CEPixelSampler/mac_instructions.jpgYou’ll get a warning when you try to save the new file after you add the xml — it says something like “This is a read only file, do you really want to overwrite the file?” I clicked yes and so far I’ve been okay.
…..aahhhhhhhhhhhhahhhhhhhhh….
Just kidding.
Hope this helps. If it doesn’t let me know.
Kathlyn Lindeboom
Kevin Camp
August 24, 2007 at 10:54 pmi’m sorry Kathlyn… i must admit i was in ahurry and didn’t fully read your description, i had read Maltaannon’s description for windows earlier, and hadn’t realized there was an instruction set for mac…
again, sorry… and thanks
Kathlyn Lindeboom
August 24, 2007 at 11:24 pmIt was confusing. I’m sorry I didn’t explain it well enough.
They say a picture is worth a thousand words — hopefully, my graphic shows it better than I explained it.
And don’t hesitate to write me if I’ve left a step out.
Here’s the graphic:
Kathlyn Lindeboom
Robert Mrozowski
August 25, 2007 at 1:27 amMy apologies to all.
The file is exactly where it’s supposed to be and can be modified as instructed.
Sorry to waste your time.
Kathlyn Lindeboom
August 25, 2007 at 1:58 am[robertmro] “My apologies to all.”
No need to apologize. We’re all learning here.
[robertmro] “Sorry to waste your time.
“You haven’t wasted anyone’s time. You proved that my directions weren’t very good, so I tried to make them better. If no one had said anything, then we would have all stumbled around and I wouldn’t have known the instructions were unclear. Hopefully, the picture has helped.
So, thank you for asking the question. Please don’t hesitate to ask others. We’re glad you’re here.
Kathlyn Lindeboom
