Activity Forums Maxon Cinema 4D CD Plugins Service Updates Available
  • CD Plugins Service Updates Available
    Posted by Cactus Dan on August 8, 2015 at 7:45 pm
    Howdy,
    Service updates to the CD Plugins are available for download. The following is a list of what’s been updated:
    All plugins now support Student versions of Cinema 4D.
    CD Joints & Skin
    A bug was fixed in the CD Bind Pose tag that caused a crash when adding poses.
    A bug was fixed in the commands that convert between Cinema 4D native joints and skinning and CD Joints & CD Skin that prevented them from being available when using the Cinema 4D save disabled demo version.
    A bug was fixed in the CD Joint that caused the Envelope option not to function when a child joint was not the first child of the joint.
    The CD Transfer Skin command will now remove any unweighted joints in the transferred skin.
    Added are two C.O.F.F.E.E. functions called “CDGetSquashValue” and “CDGetStretchValue” that will return squash and stretch values of a joint being affected by squash and stretch. These values are a percent value which can be used to calculate positions of objects parented to the joint.
    CD Symmetry Tools
    A bug was fixed in the CD Make Symmetrical command that caused the symmetry to be locked to the world orientation.
    A bug was fixed in the CD Symmetry To Tag that caused the CD Symmetry Tag to sometimes not be applied to the resulting geometry of a CD Dynamic Symmetry object.
    A bug was fixed in the CD Symmetry Tag’s communication pipeline.
    CD FBX Import/Export
    Support was added for exporting FBX 2010 through FBX 2014 for R12 and up.
    Support was added for exporting blend shape animation curves for CD Morph tags that are controlled by a CD Morph Slider tag or a CD Morph Mixer tag.
    Vertex cache export now supports choosing between Maya Cache (.mc) and 3DS Max Point Cache (.pc2).
    The above updates only apply to versions R12 through R16. Versions prior to R12 will not be updated further, although they will still be available from my website.
    Adios,
    Cactus Dan
    Cinema 4D R13 Prime
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
    Cactus Dan replied 11 years ago 1 Member · 0 Replies
  • 0 Replies
