Activity Forums Apple Final Cut Pro Legacy C.Corrector + C.Corrector 3-Way ignore alpha when limit effect is enabled?
  • C.Corrector + C.Corrector 3-Way ignore alpha when limit effect is enabled?
    Posted by Phil Muri on August 8, 2006 at 3:20 pm
    I am trying to adjust illegal chroma values on graphics that I have been given. But after applying either of the two filters (Color Corrector or Color Corrector 3-Way) and enabling the limit effect controls with th eyedropper, I lose the transparency of the graphic QT movie.
    I lose transparency only when I choose a color with the eyedropper with the limit effect control (the actual application of the filter itself retains my transparency).
    Is this the nature of the filter? Could someone verify this? Apply a CC filter to animation codec movie (w/ alpha) and enable the limit effect option. Do you still have transparency on your GFX?
    I am using the limit effect since only certain colors’ chroma values are illegal and I don’t want to touch the rest of my graphic.
    Thanks for your insight,
    -Phil
    Phil Muri replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
