Activity Forums Adobe After Effects CC Wire Removal, Clone Stamp, or Masking??
  • CC Wire Removal, Clone Stamp, or Masking??
    Posted by Daniel Elder on July 12, 2012 at 6:20 pm
    Hi CC,
    I have a stop motion video and had a discussion earlier in regards to this topic ( Stop Motion Question | After Effects or Photoshop? )
    Now, I’m looking at this stop motion footage where we harnessed the talent to a rope and a climbing harness. I have clean plate that you’ll see at the end which I could use if needed, but after testing out CC Wire Removal which was good, but not great; and masking, which could work with some care and love, and finally clone stamp which could also work with some love. I’m wondering what would you do if you were in my shoes?
    Here’s the video:
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Daniel Elder
    producer
    http://www.elderpictures.com
    Andrew Somers replied 14 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Daniel Elder
    July 12, 2012 at 8:55 pm
    No, we had no budget and the singer (girl hoisted) wanted to do something of this nature where we could levitate her. We shot about 15 different angles, takes, cut-aways, etc.
    I know this is tricky, but what can I do to make this work to the best of your knowledge.
    Dan
    Daniel Elder
    producer
  • Daniel Elder
    July 12, 2012 at 10:21 pm
    Thanks Dave,
    I figured that much, what I do have going for me is that I need to make this feel over saturated and slightly blurry with the background, so once I have all those elements touched up, I plan to do a loose mask around the talent to blur the background and the idea is that will blend in some of the imperfections I’ll likely have here. Also, good thing its only about 5 seconds of the shot I need.
    As for Rotobrush, is that a 3rd part plugin? And for the crew and the pole, I’ve already cut around that portion, so that I don’t need to worry about. The main worry is the rope and harness which will be the most time consuming.
    Dan
    Daniel Elder
    producer
  • Walter Soyka
    July 13, 2012 at 1:17 am
    Rather than trying to use the clean plate to assist in the rig removal, I’d put the talent on the clean plate.
    Maybe stabilize the shot with the talent as best as you can (so the talent stays in more or less the same place in the frame), then rotoscope the talent (ugh). Stabilize the clean plate, insert the talent, then reverse the stabilization.
    The good news is that the talent is meant to levitate in the shot, so you’ll have a lot more leeway with the tracking than you would ordinarily. Gauzy stylizing will help, too.
    Walter Soyka
  • Daniel Elder
    July 13, 2012 at 3:14 am
    Thanks Walter,
    I like that idea too, I think the styling of the shot will definitely be key with this all obviously, so once I have the sequence laid out, I’ll give both a test run and let you know how it comes out.
    Dan
    Daniel Elder
    producer
  • Tero Ahlfors
    July 13, 2012 at 6:33 am
    You could also try the color stabilizer effect to deal with the constantly changing light condition.
  • Daniel Elder
    July 13, 2012 at 3:51 pm
    Okay, I’ll give that a go too. Thanks!
    Daniel Elder
    producer
  • Andrew Somers
    July 15, 2012 at 10:13 pm
    Let me echo what Walter is saying here – it is *generally* the case that you don’t want to “remove the rig” – you want to cut out the subject and then comp them back into a clean element.
    I’m not sure what you are going for here, or why this was done stop motion, or what your intent is. I don’t understand why you would do stop motion with a live actress against a live plate – this makes no sense to me at all, unless you are trying to get that “king kong” effect to match with other stop motion animation??
    TO MAKE A CLEAN PLATE: Do you care if the plate is static, or do you want the trees to wiggle and shimmy as they do there in “stop motion” ?
    If static, then simply take several frames from various points in your clean element, and stitch them into a single tall still element, and then keyframe that to match the tilt down.
    If you want the jiggly/jittery trees, the create a synthetic plate using your A element, and the clean element, time warping the clean element as needed to match the A element tilt down, and then use garbage masking to combine the two, using the natural geometry of the scene to hide the transition.
    If you want natural waving leaves, then shoot multiple elements at normal speed for several positions through the tilt. Make sure each one is long enough for the full shot. Overlap each one about 50%, then stitch together and keyframe the motion as per the static plate above.
    ROTO:
    Use MOCHA to roto the entire girl, paying particular attention to the top edge of her, and wherever the black guide poles enter frame.
    It is best to use multiple separate rotos for various body parts. You can do a basic garbage roto around the lower white skirt thingy.
    You will need a separate roto around the top of the dress where the rope extends, and this needs to re replaced with a dress element that is not “pulled up”.
    (for the pulled up dress, try the MESH WARP efect to flatten it, or paint a flatter element to lay over in association with the roto).
